- Oct 6, 2006
How does encapsulation technology work? First we emulsify all the oil and physical contaminates within your carpeting, then surround each molecule with an acrylic-polymer barrier that prevents it from reattaching itself to the fibers while drawing it to the surface using controlled evaporation. This immediately allows the carpet to return to its original orientation so that it looks its best, not just after cleaning, but between cleanings. Approved by all major carpet mills, encapsulation cleaning could be the perfect option for your commercial grade olefin, polyester or nylon surface. Give us a call if you would like to learn more about Encapsulation and you’ll be amazed to find out that you didn’t need to settle for the results you’re use to.
