Flow and pressure poll
Lets keep this simple.
In regards to average residential HWE carpet cleaning
What flow is your wand spraying at and at what pressure?
sweendogg
David Sweeney
using a prochem quad Jet. : 12 flow 600 psi. Using a greehorn: 10 flow at 600, but getting ready to go up to 15 flow.
daniel@procarpet
I guess I need to up the flow on one of my wands. I run standard 6 flow at 450. I know I am wasting heat. I think I will up the flow to a 12, 6, and 8 flow. The reason I am concerned about uping the flow is using too much water. Right now turning the water on is not really an option on some of the rentals I clean. Yesterday I cleaned a house that I used a pump sprayer for most of the job and hf for two rooms, keyed the wand on the back stroke only, and did everything I could to conserve the 75 or so gallons I had on board. I was working my down the steps which was the last thing I had to clean and ran out of water with four steps left. I had to knock on the neighbors door to get permission to hook up to their water supply. This rarely happens but would happen a lot more if I doubled my flow rate.
joeynbgky
Joey
450-500 psi. whats a flow? lol new bentley stock wand so whats the flow
Loren Egland
Loren Egland
Are we comparing apples to oranges?
I am at 450-500 psi with 5 number 2 jets. BUT, I am running 3/8" solution hose so I maintain more pressure and flow than 1/4". My Powermatic has a pressure regulator instead of an unloader valve, so I don't drop 200 psi when I pull the trigger. Only about 25-50 psi difference. Bottom line, more pressure and flow at the same machine settings.
At least that is my understanding, so correct me if I am wrong.
CleanEvolve said:
Whatever flow my TM came with?? and 350-450 psi.
Flow= Your jet size. Like 11002, 9502 the last 2 numbers tell you what size jet it is.
I'm running 12 flow @ 400-500psi with 1/4" solution hose. My gauge drops about 100psi when keyed.
