found an alternative manufacturer/supplier
sassyotto
Paul
found a good manufacturer/supplier for Furniture Tabs
http://www.a-aexportinc.com/
they just got their website up so its not perfect yet, but their customer service is extraordinary.
I use the 5x10 foil tabs. I split them in 1/2 for large furniture legs (makes a 5x5 tab) or split them length wise to put under doors that touch the carpet.
If you are interested in these, please be aware that these foil tabs are made in different thicknesses so make sure you get a thin one (fold and split much easier) I would recommend .08, .10 or .12 thickness, but they will send samples for you to check out.
DAT
Bill Cheryl
What are foils good for? I just use sticky
Foil can be wrapped around legs to not fall off when moving furniture.
Sticky tabs do almost as well.
Remember using wood blocks?
I love wood blocks. Customers would save them so they could be reused next time.
Bob Pruitt
Robert Pruitt
The foil tabs looks so bad when they dry. Feels like littering to leave them in a Customers house. The clear plastic tabs are kind of redundant if you are using stick tabs...which of course I am.
Reactions: SamIam and BIG WOOD
They’re sticky enough.
You can’t leave a roll on your dash for two years , idiot.
Work more or shut up.
Reactions: Jimmy L
sassyotto
Paul
Just dry stroke, tell client can't clean safely, will eventually ruin Carpet so have it fixed.
what? But I can clean it safely and a lot of times there are filtration lines behind doors because ----- wait for it----- most other cleaners tell the customer they cant clean it safely and it will eventually ruin their carpet. Since I CAN clean it, are they gunna call any of the others back?
sassyotto
Paul
If I am correct the sticky tabs are a product of everyones friend, JB so I'll pass just for that reason
