generic/aftermarket hx's?
Read some old threads about blue baron, considering they are still going have they got through what looked like possibly a rough patch?
any other aftermarket makers worth looking at?
Im considering a winter time project with a 20hp engine
Not only do you need the hx but you also need the control system to regulate the heat. You will need a bypass if you do flood work.
Reactions: Hack Attack
Be very careful with how you regulate heat in any hand crafted truck mount you may make.
If you don't have a reliable method of bypassing excess heat, the steam build up in a heat exchanger can create a dangerous explosion (and its happened).
My guess is you've thought of this though.
clean image
Carl Maddock
call don, used to be called hot heat exchanger, not cheap- start at 1200$ im guessing, for lo pressure unit
If I can find a hx I'd put a LG relief on as a minimium, still weighing up pros and cons of buying another TM and just putting my predator into a trailer
I've got several regular apartments that my high roof transit can't get into the parking area at back. But a trailer unit could.
And its a pain waiting for that 1 parking space outside that apartment on the street to run hose up the outside... and it always goes down a treat with the cafes and restaurants ground level lol
Cobb has one blower/exhaust
And as posted the hot heat exchangers
