HydraMaster Multi-Surface Glide
Ive tested (and made) this and if you own a Evo13, it's a wise purchase to get more out of that wand..
Bryce C
DFW
Bryce
What is the point of leaving a big air gap right here that would seem to create a major loss in moisture recovery? Is it because the squeegee portion would otherwise cause it to lock down?
The squeegee was an afterthought that helped deal with the reduced velocity of the immense vacuum chamber on the Evolutions . By containing some of the lost air flow that occurs on the back side of my hard surface Glides it greatly improved how the two work together, but it's not crucial to have a full vacuum seal with these hard surface Glides
