Hydro Force question???
L
Larry B
Is there any fix for a HF that is filling the jug with water and not sucking any chems out?
Yep, your local o0r not so local disty should have a repair kit.
Two O rings a spring, a ball and some gaskets.
L
Larry B
Thanks guys.
Had this thing setting around for a year thought I should see if it can be repaired..
Yes there is! throw that away and get a pump up sprayer. You
can get all the chem you want. :lol:
L
Larry B
Its in the trash. I have 2 that work so I really dont have a need for the adjustable piece of crap.
Cleannz
I had the same problem with my Hydroforce and in the end all it needed was to be stripped down and cleaned. Worked fine after that.
P
Pmatte
Multi-sprayer...(so that way you're actually putting chems down and not so much water.)
Fred Homan
Take it apart and clean it. There is an internal filter on mine. Cleaned it and it works fine.
