- Oct 6, 2006
Starting at 7 am today...
If you hook up inside to a faucet and run hot water.Is there a way to warm up or insulate the feed hose so the above does not happen as easily?
Big project gotta start early
I can work great in the cold.
...the heat, not so much.
Yes, go to HD, and get a bunch of foam pipe insulation. They come in 6’ lengths, and they are like 2$ a piece.... I run them on all big commercial jobs I do in the winter.... and I work in weather down to O F, to minus 5- minus 10..... easy peasy.....Is there a way to warm up or insulate the feed hose so the above does not happen as easily?
I saw that movie. Is that from the "Shining"?![]()
