JoeBilt manifold for the Bentley stair tool
Bob Foster
excuse the clogged jet
Bob Foster
That glide is not one of Mytee's better products. I need a GreenGlide for it and my 12 inch Bentley wand.
Joel D
i like the idea. i think this is the way to go. adjustible angle that is.
how are the dry times?
can you clean a room fairly fast compared to other wands?
can i get a bentley with the sheer kit already on it and just skip the other manifold?
whats wrong with the glide?
thanks
Erik
Cleaning Professional
Erik
Whats wrong with the jet?
Joe Bristor
"i think this is the way to go. adjustible angle that is."
Thanks. I agree. So do most others using these high sheAr kits.
"how are the dry times?"
Not good with this particular wand, but they're OK.
It seems to have more to do with the glide rather than the effect of sheAr.
"can you clean a room fairly fast compared to other wands?"
Again, don't confuse the effects the glide vs the shear. The glide tends to grab, thus slowing you down, but it DOES agitate well. LOL. I see you use the gls. Excellent. It was meant for agitation. Get a glide for the slide. The shear tends to speed you up, depending on angle, soil load, etc.
There's at least two options for glides. Google and ask others for input.
"can i get a bentley with the sheer kit already on it and just skip the other manifold?"
Yes you can buy it with a shear kit installed.
Like glides, there's options; mine as well as others.
No longer are you tied to fixed jet placement.
Look at degrees of freedom in your decision on which wand to get if you want adjustable shear.
I sell most of the wands stock, like PC, WP, CMP, PMF, HM, US Products, Bentley, etc but my specialty is helping guys with custom wands. Personally, I love the custom carbon fiber, CCF, you just have more options than with most other wands.
Like Cool Cuffs, I've made a family of shear kits, all with adjustability as the key.
There's 13 bracket systems so far, and several spraybar/manifolds.
But there's only one ARC. That's what I'm protecting.
"whats wrong with the glide?"
I'll let others comment.
"Whats wrong with the jet?"
It's partially clogged. duh.
Just pull it, remove the jet screen and wash under a sink and reinstall.
Bob, your pressure's up too high for that tool.
It ain't a 10 flow GH.
It's a 6 flow CCF stairtool.
Bob Foster
I had the psi set at 500. As I mentioned above that picture I knew the jet was clogged and hadn't got around to puling it apart like Joe suggested. When I'm cleaning with my Greenhorn I'm usually at 500 and that just happened to be the setting I was using for the pictures.
The glide sure isn't a GreenGlide.
When I told Joe I was having issues with my stair tool he called me to follow up. I never had to go chasing him or hope he would return my calls. He actually was upset that I never called him back to let him know if his suggestions he gave me worked. He genuinely cares about making sure things work the way they are supposed to.
