- Oct 6, 2006
Ya, i did for the most part where i can do that, hallways and open area... I barely made any puddle that day"look Kid, here's how you do it right so you won't spray puddles and how to use effcient, consistent, straight wand strokes whenever possible "
Derrick,
The carpet came out well abd dried fast regardless (because one can cheat here) but in many situations uneven drying (and soil removal) may cause issues, especially with a portable...
The devastator needs a dry pass?!
My faith is shaken now...![]()
Oh, I got the dig. Not bitter about it, just so you know.
A whole different ball game when the camera is NOT on.
Dat's good.Hows that?
Im way slower and methodical than DAT..
Oh jeez, i thought i was doing good job. Doing cubicle was awkward enough, but i was slow and methodical in the office rooms and hallways... And i did do my dry passes too.. most of the time.
I saw on most of his wet passes that they were on pulling the wand back only. Allot of times you can skip the dry passes if the carpet isn't too bad.Dry passes were not consistent or complete.
I'll do a video soon
Ok then, ARE YOU GOING TO BUY ONE? Can you use it with you’re porty? Will it make you a better cleaner? Are you going to actually use it to it’s potential? No, in the video, you WERE NOT DOING DRY PASSES. I’m surprised Mike didn’t jump on ya for that. Even with my over driven 47 blower, I run 1-2 passes with my 14’ Prochem, or my AW29.... it ain’t clean until you suck as much out as time and fibre type allow....
No, I am not gonna buy as of this moment. It not in my budget right now. Can it work with Porty? Yes, absolutely. It will outperform the aw29 greatly... As long you have good vac to make it worthwhile. Since this is was set up as 6 flow, it would definitely need to be changed to match porty flow capabilities.Ok then, ARE YOU GOING TO BUY ONE? Can you use it with you’re porty? Will it make you a better cleaner? Are you going to actually use it to it’s potential? No, in the video, you WERE NOT DOING DRY PASSES. I’m surprised Mike didn’t jump on ya for that. Even with my over driven 47 blower, I run 1-2 passes with my 14’ Prochem, or my AW29.... it ain’t clean until you suck as much out as time and fibre type allow....
