- Oct 6, 2006
The switch never fails..Not true. The pump eventually fails.
I throw it away and buy a new sprayer.
Plastic popettes hold the plastic solution jug shelf in placement remove them and you have easy access to the pump. Everything is fairly straightforward. Gene has diagrams, wiring schematics and parts list on his website.I've had one for a long time and it works great.
However, fixing them is a real pain. Very hard to access and fix. Last time I needed it fixed, Jeff did it and told me never to bring it back. Just buy a new one.
I've only replaced two switches over 16-18 units 8nto the last twenty years. We wear pumps out every now and then. We will spend several hundred in new lances, guns and hoses every few years to make them feel new and improved operation.
The will ugly our before they need to be replaced. We bought 4 new ones last year mainly for the new look. Fixed the other up and stored them away as backup. They last forever. Ofer that's a way WAY long time.![]()
Never owned a 115-volt Multi-Sprayer, but the battery models are easy to work on.
Same switch available at auto parts stores for less than ten bucks.
Replace pump with Shurflow 8000 Series agriculture pump. 60 psi! Northern Tool. MORE POWER!
Charging system went out on one of my sprayers. Probably just a fried diode, but I got a Black and Decker two-amp charger.
Sorry Deskie, but anything that has "popettes" (what the hack is that?) or requires the use of screws, or god forbid, a screw driver, is beyond my skill set.Plastic popettes hold the plastic solution jug shelf in placement remove them and you have easy access to the pump. Everything is fairly straightforward. Gene has diagrams, wiring schematics and parts list on his website.
