My other waste tank
Somehow this brand new TOPS MF pad got sliced in the washing machine on it's initial run through...It's interesting to see the foam in there before it breaks down with use...
I think I'll do a little soil soaking experiments out in the laboratory tomorrow...
Typical democratic snarkism
"I know YOU and all your lemmings are either complete r3tards or COMPLETE r3tards to think that a Tuuway or Micro Fiber pas holds much more than an ounce or 4 of solid soil after you grind the entire house with it.
Fact. " Mikey P
"Those same scientists say that we evolved from Jimmy.
Who are you going to belive John?
One micro fiber pad holding more soil than 35 gallons of muddy water.
you..YOU are going to hell Guerkink. " -Mikey P
"you don't understand" ....
Reactions: Mike Pailliotet
Patrick Henry your 7th great uncle twice removed🤷🏼‍♂️😂
Just bought two round microfiber pads that size at harbor freight minus the stripes for 79 cents a piece. I will use them to wax the subaru
I think the pads shine the most getting the last of the dirt, after the heavy soil load is out, or on VERY lightly soiled carpet.
In your quest to run off every advertiser on this forum maybe you could use your limited imagination to picture that being dirty water....,,ಠωಠ
Are they going to leave because I commented on your dumbass "experiment"?
and your complacency of late and ADD are much more of a danger ...........so you can stfu with that noise
:icon_rolleyes:
Can't we just use our imagination?
The microfiber texture itself is likely to hold far more actual soil than the (compressed) foam would ever be able to
Reactions: frank fratto
As usual all the critics have never tried what they proclaim to be an expert on...
of course you are wrong. After near 50 years cleaning carpets I've never proclaimed that. I've worn out many of those pads, and over 100 earlier version. They have their useful niche, but are not the end-all tool.
"End all"
Did I say that anywhere?
Go clean 500 ft with your symex and fiber pads and clean the next 500 ft with one of these microfiber pads put your Cimex pads in the 5 gallon bucket of the hot water and do the same with the microfiber and you tell me which ones removing soil...
"End all"
We all know the Cimex isn't for removing soil. Neither is an orbital machine using fiber pads. The whole idea is the chemical doing the work, encapsulating the soil ,preparing it for removal by vacuuming. The microfiber pads can both encapsulate and remove soil at the same time. The degree to which it removes soil depends on how often you change the pads. Great on commercial but still not a fan on residential.
I have no illusions about what the Cimex does, or what straight encapsulation does. It makes the carpet LOOK awesome. With practice a 175 does as well.
When the soil load requires it, HWE works great, albeit a bit slower. It removes dirt. However if hoses, security, privacy, or such make that impractical , I'll use absorbent pads.
As I've said 10 times or more..
We all run across regular or first-time customers customers that have virtually no soil load in their carpet, just a few spots ...I'll say it again microfiber pads do a fantastic job of fixing those situations.
You can clean 500 ft² of pile carpet carefully with less than a gallon of water in an ounce of chemical (or none what so ever).. does it get any greener than that?
The carpets dry soft and fluffy and I found that even cornrowing can be removed as well as friction burn marks on commercial glue down
The doors being able to remain closed and the HVAC allowed to do what it's going to do is a big deal especially for the elderly
I've taken my rotary extractor off the truck to make room for my OP which gets far more use these days as I clean for my desired audience..
You old school fucks that want to fight with me on this I really don't give a shit what you guys do with your business but I would like to help out new guys from being close-minded idiots like I used to be and you ...want to be...
Carry-on
