need flange for Kohler command
icleancarpetz
Rafael Samson
need a flange for #8 s-flex coupling for Kohler command 27hp that spins the blower.
any ideas where to get one?
Do you have a caliper gauge? If not, use a tape measure.. Count your teeth on the inner and outer as well.. What does your coupler look like? I have a Lovejoy, i've heard of dodge, and couple others..
I turned to Amazon after buying it locally from a bearing shop with specialty parts..
This is the one I bought.. Was $18 vs $70 and my name isn't Matt! You gonna have to wake up earlier if you tryna pull the wool over my eyes.. :lol:
Amazon product
View: https://www.amazon.com/Coupling-Sleeve-Elastomer-7JE-S-Flex/dp/B0BNBBVPB7?pd_rd_w=JjsGW&content-id=amzn1.sym.4369c435-d373-4d24-a564-9c2e8fb244dc&pf_rd_p=4369c435-d373-4d24-a564-9c2e8fb244dc&pf_rd_r=1YJ4SZTVPAX2BF2PHMMY&pd_rd_wg=oIKyy&pd_rd_r=0793bc19-3b80-4c5e-abe2-57ac51b08875&pd_rd_i=B0BNBBVPB7&psc=1&ref_=pd_bap_d_grid_rp_0_71_t
icleancarpetz
Rafael Samson
I have a coupler….lovejoy size 8JE.
I need the flange that holds the coupler and key that is inserted into the shaft.
Will search around.
thx
Reactions: Nate The Great
Will search around.
thx
What's the shaft diameter size? 1 1/8'' says google..
There are abunch of different styles of couplers.. Sorry I'm no help without a pic..
KevinD
Kevin Dumas
Will search around.
thx
I might have both flanges and a epdm coupler if your crankshaft is 1 7/16.
Let me know if you want me to check.
