- Oct 22, 2012
- Name
- Ron Marriott
YupSo what you're trying to say is this place needs a little coffee?![]()
Not sure I understand your logic. When i dry pass i overlap. Everything is drypassed and it looks good.My OCD doesn't get Triggered unless I see it. I also need to give a shit.![]()
.Shark teeth are always wrong. Don't sweat itIt does look good to the untrained eye and it's a faster way to clean.
but IF you think about it from the fiber's point of view-- shark tooth isn't even.
Geez! you guy are gas lighting me now, and I'm beginning to have doubts in my belief.
especially since @anon lsaid I was doing the shark tooth wrong. ill have to analyze it again.
especially since @anon said I was doing the shark tooth wrong. ill have to analyze it again.
……….I do what my market demands, if I didn't I would be out of business!! They seem to like my service, so I will continue.. I just dry pass triangles.
I had to go to a redo that you personally cleaned, stfu!……….![]()
I had to go to a redo that you personally cleaned, stfu!![]()
Nah, she said spots came back.. Probably BS, but I serve my customers.. It was the job where we had the living room, and my guy was in the basement.. Then you did the basement stairs, actually solid stairs method..You said to half ass it.. If you had a vacuum, 75% of your work would be easier..![]()
I only overlap 1 inch.. unless I'm doing stairs then I overlap a 1/3rd-- to clean them 6 times.I'm going to assume you overlap by exactly 1/2 too right...you know so all the fibers get equal treatment
more here
The PROPER Wand Stroke
Holy Hell!!! It absolutely kills me when I see facebook and youtube videos of guys that post about carpet cleaning and their wand stroke is all over the place. Does this bother any of you or is it just me???? It makes it even worse when you see they have a nice van setup, they vac, scrub with...mikeysboard.com
"shark teeth" depending on the pattern will have a negligible difference in extraction especially given the diminishing returns of multiple passes..
True.You said to half ass it.. If you had a vacuum, 75% of your work would be easier..![]()
No.. clients say I do a better job then anyone else. most are shocked at how dry the carpet feels moments after I'm done.so you have 1 inch clean streaks?
You mean they don't notice that 1" you gave the extra attention to?Now apply that logic to a sharks tooth pattern
A vacuum can do this. IdiotYour wand technique leaves triangle/shark tooth patterns in the carpet. even if you use a rake to remove them.
It's a sign of uneven cleaning.
Same if you leave the swirls from a Rotary.
needs to be finished with a wand.
Mark’s stuff. Looks great. Takes care of any water spots or cleaner residue.
I put it on super thin. It’s basically drying as I go over it with the microfiber mop. It’s no where near the amount you would use on a porous surface.
Put what on, vct finish?I put it on super thin. It’s basically drying as I go over it with the microfiber mop. It’s no where near the amount you would use on a porous surface.
look at your prices again on restorative cleaning vs regular. I think you got the numbers backwards
I think its 25 extra on top of standard cleaninglook at your prices again on restorative cleaning vs regular. I think you got the numbers backwards
Nolook at your prices again on restorative cleaning vs regular. I think you got the numbers backwards
