Poly Tanks
jack zerkie
They have a very good operation there I used them a few times. Not sure what size tank you need but I have the 3 roto tanks from Cobb 80 gals . I used the over 6 yrs now and I like them . I flush them after each job and no smell ever. The price is fair and small in size. jz.
jwfoulk12
Justin Foulk
I'm thinking about a tall narrow tank that uses the vertical space that is often waisted in a van. Poly would be much lighter then stainless as well as cheaper. Any negatives with this type of tank?
Reactions: Russ T.
Russ T.
Russ Terhaar
I think it makes a ton of sense, if it's a well made one. Lighter, cheaper, no corrosion...
Reactions: jwfoulk12
jwfoulk12
Justin Foulk
I was originally thinking fresh tanks but I see he is manufacturing Poly waiste tanks as well. Tested to 24 HG. I am definitely intregued.
Spurlington
Spurlino
Don from TTI also mentions those tanks are easy to rinse clean as nothing will stick to them
This the tank. 2" FPT drain on end . It comes with sturdy steel mount
recovtank[1].jpg and stainless filter basket.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=72&products_id=4834
