Pro's choice fire water
kevinj6121
Cleaning Professional
kevin
Anybody ever use Pro's choice fire water? Directions say for light soil dilute 100 to 1 assuming injection sprayer set to 8 to 1.
so how many actual ounces do i add to a 5quart injection sprayer with the 8 to 1 tip on it if I choose to use my injection sprayer
OR
sometimes if i get a real bad one i like to use my 175 with solution tank and carpet brush (shower feed) and apply and scrub at the same time so how many ounces per gallon would i use in this situation
I think 100:1 dilution is way too light. But whatever. I'd just start with 8ounces in your hydroforce filled with water. That'll be 62:1
Reactions: SamIam and Jimmy L
They are such idiots with the mixing directions. I always need to pull out my calculator. Just say 4oz per gallon! Idiots!
kevinj6121
kevin
I agree, why can't all chems just flat out say x amount of ounces per gallon for pump up and electric sprayers and x amount of ounces for in line sprayer assuming 8 to 1 tip fill rat w/water, keep it simple for us simple minded people out there, lol
Reactions: Nomad74
I use firestorm, but probably a cup at 4-1 with a hydroforce.
2 cups if it's bad
I would call the tech support number they're very helpful.
kevinj6121
kevin
I actually did, i sent an email and they were quick to respond and answer my questions, haven't used the product yet to know if its any good
but the customer service certainly was good, so they get a thumbs up there
So what's the answer?
kevinj6121
kevin
I copied and pasted their email response to me, here it is
Hi Kevin,
If your injection sprayer is set at 1:8 you can add 8 ounces up to 24 ounces of product with the balance being water (with heavier soils get closer to the 24 ounces and decrease for lighter soils). Don’t exceed 24 ounces because you will encounter foaming issues. If you are using a 175 use up to 4 ounces per gallon (it’s okay to go a little lighter here with the added agitation so 2 to 3 ounces is usually fine).
Reactions: Nomad74
Hi Kevin,
That was a good response from them. I use a 7qt HF sprayer with an 8:1 or 9:1 tip. I wanted to know exactly how much I could get out of it so I sprayed it into 5 gallon buckets until the HF was empty. Turns out I get 12 gallons out of it. Knowing that made the math real easy for me.
Reactions: Steve Lawrence
Everyone should do that
Reactions: Nomad74
Let's burn that dirt right out of that carpet.
I'm assuming they got the fire word from the flammable ingredients in it. I wonder if any other companies use that term on their chems
Slop and gobble made from turkey gravy,
Hot sauce modifier, quat alot.
And we wonder where Saiger gets it from?
Saiger sauce1
The marketing genius is over whelming.
I would assume Firestorm and the word fire is for hot.
With a 13 ph it's pretty darn hot.
Almost forgot citrus crush
Prochem
The all new citrus slam
Esteem
Flex powder with citrus!
Orange you glad I didn't say banana
Reactions: Nate The Great
Not flammable but it will inflame your skin/eyes and mucous membranes.
Used a bit of Saiger sauce today. I worked on this bone white piss soaked carpet for 8.5 hours today and cleaned 42 steps in this 3 story house. I'm so tired! Now I'm relaxing with some 99 Proof liquid love.
@Mark Saiger , it's about time for me to order more
Reactions: Mark Von*Lay
Mark Von*Lay
I don't Think CTI pros choice makes a bad product.....I want to try some of Cobbs chemistry
So..
You don't see the streaks?
That should have been RE'd
That DamonWanding is gonna be the death of you....
So..
I wasn't done, just snapped a pic real quick before i did any dry passes. I wasn't lugging a RE around that place . Every room was separated by hardwood. A real pain. I already worked 8.5 hours in that place.
You guys are worse than old hens.
