Removing stripper residue from carpets
P
poseidonjack
Had a cleaner leak some onto a carpet and create staining. Any ideas to help?
Thanks
ACE
Do you mean used VCT Stripper slury? Unless it's heavy old build up. Very hot prespeary and extraction will take it right up
amazingcleansc
That cigarette and perfume mix is a real bitch. shiteatinggrin
Brian R
Cleaning Professional
Brian Robison
Oh, I thought you meant something else...carry on.
P
poseidonjack
VCT stripper. Would you apply any type of chemical to assist or simply hot water? Enzyme, encap - any recommendations?
Jeremy
Jeremy
Wet extract with an acid rinse & spotting claw. Stripper is solvent, high pH builders & surfactant if it dries it can create a wicked combination of browning, resoiling & wicking issues... Once it's well flushed post encap/bonnet & force it dry with an airmover.
rhino1
cigarettes, alcohol, and body paint should come out easy, just vacuum up the pasties before the wife comes home
