sanitaire vacuums
rhyde
Cleaning Professional
rhyde
FYI,... the motor on our new Vac was wired in reverse the brush should spin towards you not away about a 10 minute fix and makes a big difference. Not sure if this a one off thing or all the vac are like this
Steve Lawrence
Steve Lawrence
The belt can be installed to make it go either way. There's a guide on the vac body to show you the right way.
Nate The Great
+1. I've put on the belt backwards on my turbine vacuum once :oops: . Most times there is a guide like Steve L said.
cleanimagemarketing
Isn't it just personal preference? I always like mine so the brush is resisting on the pull stroke...
