- Oct 22, 2012
- Name
- Ron Marriott
Would the older model 870 like Damon's fit into a 3/4 ton van? Or would it be too heavy?
Actually, I had the Amtex in there at that time. I had to poop bad.Tell him about the time you got trapped in back and couldn't get around the 870 to the cab or side doors
Mines the regular wheel base. I don't usually use a hose reel, I just hang my hoses instead. Looks like it's doable. I'd have to see how to convert it back to gas and get a fuel kit. I really don't need all that power but better to have too much than not enough. Probably be the last truck mount I would need to buy.Here is a video of the inside of my can. Its tight. Glad I moved up to a Promaster. But it will give you a better idea what I was dealing with. Keep in mind also, the van in the video was a short wheelbase.
Be nice to find a propane van as well. Propane is almost half the price of gas. The people selling the machine had it in a trailer using forklift type tanks to power it.should be cheap as chips to run on propane, heard of guys here running 570s and 575s on propane as thats how that engine is configured to run in forklifts
older model 870
Only 11 hours on it
Asking $15,500.
I thought they sold it but just saw a new ad
I am always skeptical. I might just take a look, see if they let me run it up. I think it's been difficult to sell because of the propane conversion but it could have froze being in a trailer.what's the guy's story and what's wrong with the TM?
colour me a skeptic now
thinking sump'ums gotta be wrong ....froze maybe??
.LT.A.
Also good point. My van was a 1 ton. So keep that in mind.I would be concerned about putting a unit that heavy in a 3/4 ton van. You need to add in the weight of a full waste tank too.
Wish I was there to help you out. I would run it through some sea-trials for you. 11 hours seems like a really good deal. Almost too good to be true. Really the best way to get to know it is to fire her up, clean some tile with everything turned to max and psi set at 1200. See if she blows apart or leaks. Be sure to turn off the chem injection pump though, you don't want to chew up the rubber pumper thing.I am always skeptical. I might just take a look, see if they let me run it up. I think it's been difficult to sell because of the propane conversion but it could have froze being in a trailer.
Their initial price was $40,000, which I guess was close to what they paid for it. Price kept dropping, last I saw was $25,000 then it disappeared. I thought they had sold it. Just saw it advertised again for $15,500 by what looks like the same people, same area. My first thought is what is wrong with it. I'll get in touch with them and see whats what.Wish I was there to help you out. I would run it through some sea-trials for you. 11 hours seems like a really good deal. Almost too good to be true. Really the best way to get to know it is to fire her up, clean some tile with everything turned to max and psi set at 1200. See if she blows apart or leaks. Be sure to turn off the chem injection pump though, you don't want to chew up the rubber pumper thing.
Famous last words. Better bring my measuring tape.What could possibly go wrong?
The 870 weighs about 1720 lbs with console, tanks and hoses. Add another 1000 lbs for a full waste tank and you're almost at the limit. Add a 200 lb driver and that's about it.donno about Dudge vans
think Chevy's 3/4 ton vans 8600 GVW and Ford's is 8900
empty cargo van weighs in around 4700 give or take
3500+ payload capacity
what's the 870 weigh?
and capacity of waste tank? ('case you can't drain on-site and have to carry carpet nectar)
and how many CimexSpiderBorg machines do you carry?
.LTA.
