Spray tip size for Multi-sprayer???
Fred Homan
What size spray tip do you guys use for your Multi-sprayer cordless sprayer? Any different size for upholstery? I really like the Tri-plex protector from Craig Jasper.
I'm not at the office, so I can't go look to see the sizes.
I use the standard tip to apply presprays for carpet, deodorizers and scotchguard.
However, I use a finer tip to apply upholstery prespray and solvent protector to upholstery.
can't read the jet size on ours, cause so old and beat up.
But I "think" I put an 8006, but it's probably more like an 08 or even 10-12 flow now
cause the last time I bucket tested it, I was getting right at a GPM flow.
If i recall, it sprayed 1 gal in 65 seconds .
The newer electric sprayer we use (same flowjet pump, only in 110vt) sprayed a gal in like 70-75 seconds "if" I recall right.
That's with new/newer 06 flow jet
I "think" our Multi came stock with a 6506 jet on the carpet wand and 6515 on the stubby
I generally use a HF 1/2 gal pump up for upl though .
Unless it's a trashed olie/poly synthetic, then I'm not shy about hosing it down with what ever is in the electric sprayer ..even Powerburst.. :shock:
