- Oct 6, 2006
Probably enough soap left over in the carpet to make work.Why not use just water in just one area?
Probably look great.
TRS does too F'Only one advertises here
The vac a way probably has more scent and viscosity.The verdict is each of them take two wet passes to produce the same results.
If not for the scent and viscosity you'd never know the difference.
No big surprise.
The Damon one will choke you out of the room. But works great.The verdict is each of them take two wet passes to produce the same results.
No big surprise.
Have you tried Angry Lemon from Damon? It has a good scent and is the equivalent to Commercial Magic. I’ve never smelled Commercial Magic though.The Damon one will choke you out of the room. But works great.
Will it make me cough? I know he sells good stuff but some things are just too potent for my perfect pink lungs.Have you tried Angry Lemon from Damon? It has a good scent and is the equivalent to Commercial Magic. I’ve never smelled Commercial Magic though.
Explain the term ......straight encap
Doesn't that just mean............bonnet cleaner?
This whole VLM lingo about encapsulation is just BS.
Either it has a polymer in it or it doesn't..............which defines an encap
I would never count on a polymer encap to encapsulate...............anything
But I do look for one that leaves a DRY RESIDUE
I use fibre pads all the time. No absorbtion at all. Yet the carpets still look great. I have a twin tower condo building, 32 stories, that I have been encapping for 3 years now. The carpets look better now than when I was cleaning with a high performance portable.I meant straight encap as in only using a fiber pad while cleaning as opposed to extracting with either a bonnet (microfiber, cotton, etc) or HWE. Green Dragon doesn’t have polymers in it and dries with no residue.
I use fiber pads only all the time too but it’s not recommended with Green Dragon because it doesn’t have a polymer. If I’m only using a fiber pad I use Awesome Encap or Angry LemonI use fibre pads all the time. No absorbtion at all. Yet the carpets still look great. I have a twin tower condo building, 32 stories, that I have been encapping for 3 years now. The carpets look better now than when I was cleaning with a high performance portable.
I have been using Bridgepoint products as well as Harvard's encap. I have had good success with the o2 products on coffee and other beverage stains.I use fiber pads only all the time too but it’s not recommended with Green Dragon because it doesn’t have a polymer. If I’m only using a fiber pad I use Awesome Encap or Angry Lemon
