Raffle The Prochem One Two Punch Raffle!
Win one case of Ultrapac® Pre-Treat with LVC AND one case of All Fiber Deep Clean!
A $270 value.
Four winners will be drawn.
Ultrapac® Pre-Treat with LVC S903
Heavily soiled carpets require specialty pre-treatments, and Prochem Kärcher Group’s line of Ultrapac professional carpet and rug pre-sprays won’t let you down! Used as the gold-standard in the industry and a cleaning benchmark by carpet manufacturers, the Ultrapac line of pre-sprays is the number one choice for professional carpet and rug cleaning. Ultrapac’s powerful blend of industrial-grade surfactants, detergents, and premium-grade solvents break down grease and oily soils to create maximum soil suspension, and a pH under 10 so it is strong enough for commercial cleaning, yet meets specifications to preserve the stain-resistance warranty of residential 5th generation carpet. And, the Ultrapac line is concentrated and economical, 1 gallon makes up to 33 gallons diluted pre-spray!
For a dynamic dirt-busting combination, boost your Ultrapac with Prochem Kärcher Group’s Citrus Pro, and extract with one of Prochem Kärcher Group’s premium alkaline or acidic extraction rinses such as Liquid Slurry, Dry Slurry, or All Fiber Rinse.
When the carpet cleaning industry first became interested in levels of Volatile Organic Compounds (VOCs), Prochem introduced Ultrapac Pre-Treat with LVC. Ultrapac Pre-Treat with LVC was one of the first low-VOC pre-sprays in the industry. LVC stands for “Low Volatile Compounds” and was an early term for “Low VOC.” In addition to its very low-VOC formula, Ultrapac Pre-Treat with LVC has no added fragrance. The mild detergent odor will dissipate within a few minutes of use. Ideal for use in residential and commercial properties where fragrance-free products are preferred.
• Fragrance Free
• CRI Seal of Approval
pH: 9.5 - 9.8 ready to use
Coverage: 1 gallon makes up to 33 gallons of ready to use solution for approximately 400 sf per diluted gallon.
All Fiber Deep Clean S103
A liquid extraction agent designed specifically for use with truckmounts and portables, All Fiber Deep Clean is an acidic extraction rinse powerful enough to be used for residential and commercial carpet cleaning, as well as on many upholstery fabrics. WoolSafe Approved and excellent for use on synthetic and wool fibers. New generation polymer technology encapsulates and crystallizes soils and pre-spray residues for maximum soil removal with minimal residues. Concentrated and economical - 1 gallon makes up to 65 gallons of extraction solution.
· WoolSafe Approved for Carpet, Upholstery, and Textile Extraction
· Brightens Dull Fibers and Leaves them Soft to the Touch
· Polymer Technology Helps Prevent Soil Wicking and Browning
pH: 5.2 - 5.8 ready to use
Coverage: 1 gallon makes up to 65 gallons of ready to use solution for approximately 400 sf per diluted gallon.
will this stuff work in the new Genie i'm building and will be available soon........
you mean ...i wuz RIGHT? errrrr yes i WAS right you big goofball........
so it WILL work thru my Genie thats almost finished and will be for sale soon....and will be very competitively priced....cheeeeeeeep wit the lifetime guarantee....!
