Upholstery cleaning overspray protection
safeclean
When cleaning a customers upholstery what do you guys use to protect the floor from over spray at the moment I use a plastic tarp would a cloth drop sheet be better as to absorb the over spray.
Craig
Contemporary Carpet Clean
buy a hydramaster drimaster upholestry tool.....no over spray with that tool ever!!!!.....been there done that with tarps/moving blankets....spend the 400 bucks and be done with it....it will then be one of the tools on the truck you'll never want to be with out!!!
J Scott W
Jeffrey Scott Warrington
Furniture moving blankets are what I used most often. You can also get disposable drop cloths with one side plastic but the other side some absorbent material. Use with the plastic side down. These did a better job and were lighter weight than the moving blanket. I just did not buy them all the time since I already had the moving blankets.
Scott Warrington
Chads
I try to just clean the furniture first then clean the carpet. this stratgey doesnt work every time though i love to clean furiture outside on the concrete where i can have plenty of space. just all depends on the situation what kind of help you have and what type of upholstery your doing.
moving blankets
nice on wood floors, can slide the furniture around.
No over spray with the SW HK tool, just on preconditioning.
Greg Loe
I use the canvas tarps. Seen a moving blanket bleed color before.
Art Kelley
A 6X8 area rug works well along with a few towels.
If I have to put something down I use the painter drop cloths.....
Most the time I will do it right over the carpet and then clean the carpet when I am done ( with the clients permission)........
You would be surprised how many times you will get called back to book the rest of the home.....
KevinD
Kevin Dumas
I'm with Richard. I've used everything and the vinyl backed sofa blankets are the best.
I have cleaned 50-60 office chairs on them and it does not wet through.
Machine wash once they get soiled although you need a pretty good size washer to get them real clean.
