Vario OP assist handle
ieY0GWjpXcNYlC0rk02gBgfol0nck4YiG6u_KkJZKZhQQmKxmB1Pr9gmC4hJtXQ4v6W7V29uFiHrNGR9Vc=w1698-h955-no.jpg
Damn but it sure do make picking it up easy..
I just hope that velcro under those weights holds...
You'd think Rick would correct this design flaw. I am sure he's working on it.
Rick?
The strap should hold fine as it appears to be an Atwood boat ladder assist handle rated above 250 pounds.
If the whole area under the weights has Velcro it should hold up for a good amount of time if taken care of and care is taken to make sure all,Velcro is seated or mated well before a lift takes place.
Are you sure it is there to be an assist handle or is it there just to transport the weights?
Either way, with care should last a while.
Drive another screw on each side of the handle a few cm from the other screw.
