- Oct 6, 2006
@Mikey P have you changed the title of your thread or did I not read it properly earlier?
If asking about specific dyes I've no experience with "Rit dyes" is that what the guy you contacted uses?
That's what I do at times. Not a permanent repair but will last until next cleaning at least. Sometimes several cleanings. Easy to start with a light color and work up to the original color. Good temporary repair on olefin and polyester carpet that won't accept traditional dyes.Just rub and go?
Probably does but I've never noticed. I have a condo tower where the janitorial loves hydrogen peroxide cleaners. Nylon commercial carpets, mainly brown and green. I am able to blend the colors a little so that you don't notice. I clean them every year and most of the time I don't have to retouch.the oily residue doesn't attract dirt?
Since the title change to Rit Dye, I have bought in the past to see if they met stick to and correct some of the color damage on olefin and polys that we see. did not seem to help at allThat's what I do at times. Not a permanent repair but will last until next cleaning at least. Sometimes several cleanings. Easy to start with a light color and work up to the original color. Good temporary repair on olefin and polyester carpet that won't accept traditional dyes.
I haven't heard of this. Can you expound for the uninitiated?Just rub and go?
I think using and iron to heat set it, not sure thoughJust rub and go?
Oil pastels are available at most Arts and craft stores. They come in a pack of assorted colors like crayons but they are softer and flow better. They are not designed for carpet color repair but can be used for temporary color touch ups. I had an old carpet cleaner show me years ago and it's something I have used when the customer can't afford a full color repair. Simply choose a color similar but lighter than the color you are trying to match. You can use volatile solvent to blend or remove color. Add darker color slowly until you have a close enough match. What I do is very similar to what's in that video. Add and blend, add and blend. Too much? Remove with solvent. Use a trigger spray to avoid too much solvent as it will delaminate the carpet.I haven't heard of this. Can you expound for the uninitiated?
Hey Its fun!Oil pastels are available at most Arts and craft stores. They come in a pack of assorted colors like crayons but they are softer and flow better. They are not designed for carpet color repair but can be used for temporary color touch ups. I had an old carpet cleaner show me years ago and it's something I have used when the customer can't afford a full color repair. Simply choose a color similar but lighter than the color you are trying to match. You can use volatile solvent to blend or remove color. Add darker color slowly until you have a close enough match. What I do is very similar to what's in that video. Add and blend, add and blend. Too much? Remove with solvent. Use a trigger spray to avoid too much solvent as it will delaminate the carpet.
what have you been up to Willy?Are we talking about Jimmy's sex life?
Wax crayons are better.
Use a hair dryer to melt the wax into the fiber.
It's permanent.
If working on Sisal, use boot polish, you may need to mix different colors to obtain the correct color.
Some can even be done (rental vacates) using chalk.
Has anyone tried these?
I have had much better luck, if you want to call it that, using pemenant markers for a quick fix. Good enough for rentals.Wax crayons are better.
It's permanent.
Oil pastel crayons
after I get back from Nova Scotia where I'm hoping to close on a sweet little house.
Yes, I have. I do color repair.. I tried these to see if they could help on the olefin, and polys, that are not supposed to sustain color damage, BUT DO!
I could not make any improvements on those.
I have a few pictures somewhere of damage on those fibers. If you like I will try and find and post. I have in the past, but not lately.
AND ,, doing this stuff on line is not my strong suit!!! LOL!!(not techy, )
Blandford in Lunenburg county. My family's been in that area since the early 1700's. Maybe I'll find the Oak Island treasure is buried in my backyard..I remember you letting us know about this. I hope it all works out.
What area of Nova Scotia is this sweet little house in?
And a damp towel under the iron allows the wax to absorb into the towel so it's not stiff afterward.I think using and iron to heat set it, not sure though
