Where do I buy this 2 1/2 hose from?
alazo1
The second picture in lester's post has a 2.5 hose going from waste tank to another box. Looks like it would be more flexible then the 2.5 I have.
Any idea?
viewtopic.php?f=1&t=17995
Albert
L
lesterj2
Brian is correct that hose is not very flexible at all... to be real with you its stuck in that very position... and by the way what is that box that its hooked up to... i opened it and it has like a screen sock thing in it... with the vacuum hose on the other end you can see it i the pic also...
L
lesterj2
Brian Luddy said:
Filter box.
so that vacuum line is in the correct spot... if so do i connect the wand to the other end of the vacuum hose...
and on the filter box it also has some spots for other vacuum hoses on it... but they are covered with some type mesh cover or is that for breathing purposes... correct me if im wrong...
alazo1
Figures, I guess it would be dumb to have a very flexible hose to perform that function. Just looked at it and thought it was the cousin of the carwash hose. One day someone will make a 2.5 hose that's more flexible.
Albert
Albert
Not likely for carpet cleaning, heat and high vacuum requirements leave you with what you got, if there was some space age technology that would fit the bill it would be much more expensive, that right there kills it for most as an option.
Honestly, I don't think the 2.5 most have is that hard to work with. If you ever move to a larger TM, the carwash shrinky dink hose won't be an option anymore.
L
lesterj2
LMAO @ carwash shrinky dink hose...
just what is carwash shrinky dink hose.. LOL
that is a 50' section of hose that is very flexible, it kinda stretches when you pull on it, when you have a 50' hose pulled to 55' and hook it up to a truckmount it recoils quickly and will now be a 45' section of hose. :shock: Real interesting when it's 100' long, snaked through the house and there is a wand attached at the end.
alazo1
It already has. Ever since I put the y. Your's is hanging on pretty good though.
Albert
L
lesterj2
so Greenie what you are saying is with a 50' shrinky dink hose after time you can make it wear out to a 55' shrinky dink hose...
no...you can streeeeetch it a few feet....but look out when you fire up the beast.
