- Oct 6, 2006
they all areMy SS12 is Flared to take 2 inch hose.
So on your 2” straight u ran a 8’ whip with a 2” cuff ?I used both sapphire wands yesterday with and without a 8' whip.
I've come to the mature veteran cleaner conclusion that only idiots asking for joint issues, wouldn't.
If you know how to wand, 2"straight might cut off 5 minutes of dry time on a humid day with the windows closed and a plugged up filter.
CorrectSo on your 2” straight u ran a 8’ whip with a 2” cuff ?
Tapered ?Correct
No, those tapered hoses collapse/kink too easy.Tapered ?
Or you can pretend you have a penis and use 2” hose.No, those tapered hoses collapse/kink too easy.
Just 8' of good ol' porty hose
I've been using the 1.5 ss12 for about a week now and my biceps are throbbing.
I realized when I used the 2' -14 Dev wand I would use my legs more and my biceps less.
With the smaller the wand I let my guard down and changed my technique, using my biceps more;
I'll be more aware and correct that.
Wasn't it you that said a 2 ply tapered hose was available somewhere now?No, those tapered hoses collapse/kink too easy.
If I did, I was wrongWasn't it you that said a 2 ply tapered hose was available somewhere now?
I remember reading something somewhere.
If your brain functioned properly, it would realize it’s full of shit when it talks about five minutes more dry time using a whip.Id rather pretend I have a brain.
I use a whip and have fast dry times. Humidity plays a large part.If your brain functioned properly, it would realize it’s full of shit when it talks about five minutes more dry time using a whip.
I thought you were using 2 inch all the way?I use a whip and have fast dry times. Humidity plays a large part.
No. I switched to a whip and a 1.5 dev wand.I thought you were using 2 inch all the way?
You've got the right machine for it.No. I switched to a whip and a 1.5 dev wand.
Did I say five? I meant two...If your brain functioned properly, it would realize it’s full of shit when it talks about five minutes more dry time using a whip.
I find it all depends on the carpet. I always have 2 inch and 1.5 inch on the truck. When I get into heavier carpets, I go two inch. Average carpets, 1.5. if I put my 2 inch pmf/cleanco wand on my 47 blower, it's really hard to move it. Tears my shoulder up. Works good on my 45 blower. My westpak 2 inch with the green glide works great with the 47. Glide is more rounded and easier to push. My pmf mach 12 works great with both machines. I'm sure the Sapphire is almost as good.Did I say five? I meant two...
It was 2 ply toilet paper as I remember.Wasn't it you that said a 2 ply tapered hose was available somewhere now?
Only when the humidity is -19.Did I say five? I meant two...
