- Oct 7, 2006
- Name
- Larry Capitoni
Some guy I met has a new Champion inverter generator . (2000/1700 wt)
He won it in a raffle and has no use for it ...wants to sell it
I want to buy if it will suit my field use needs
I'm reasonably sure it's plenty to run a 15amp saw
But what about a compressor that runs more continuous duty cycle with framing nailer or a couple roofing nailers ??
will it hold up to that type use?
will it cook the inverter or pop the reset if someone uses the saw while the compressor is running?
thanks
I sure would prefer to load 50 pound gen instead of 200 pound 5000 wt when lectric isn't available or convenient
..LT.A.
thanks
..LT.A.
