- Feb 4, 2016
- Name
- Matt w.
If APO's are needing that, then we're wasting waterSo, just fill your take halfway every morning before your first job.![]()
What pumpout is this? Inquiring minds want to know.. Asking for a friend……![]()
Matt, I have your answer but I haven't had my coffee yet so I'll keep it short.So, just fill your take halfway every morning before your first job.![]()
Prime? So during the job, stop what I’m doing, walk 300ft back to the truck, disconnect the hoses, and turn it on, connect the hoses, walk 300ft back to the wand. Yes you’re right. But I was never instructed to do that and yes I did do that, but I feel that if it needs to be primed, then it’s not made for me.Matt, I have your answer but I haven't had my coffee yet so I'll keep it short.
Prime under low suction, then it will pump out on full load.
I didn't think you would get it. You can't grasp the concept of a filter.... which by the way, is even more important when using an APO.Prime? So during the job, stop what I’m doing, walk 300ft back to the truck, disconnect the hoses, and turn it on, connect the hoses, walk 300ft back to the wand. Yes you’re right. But I was never instructed to do that and yes I did do that, but I feel that if it needs to be primed, then it’s not made for me.
Are all the apo’s meant to be that way?
If you park in the Handicap spot you'll only need to walk 100ft.So during the job, stop what I’m doing, walk 300ft back to the truck
This was my first use of an APO and I was never told to prime it during all the reports I told him about it not pumping out.Pretty much any APO you need to prime it without load for it to run..
All redheads are weird
And in conclusion to my testing, there was nothing wrong with it if it needs primed.
Now it's time to invent a APO that doesn't need primed for people like me who've never used one
and some never do.No point in reinventing the wheel.. Now you know.. It's okay as everyone learns differently..
NephilimNo souls
Wrong kindI do use a filter. Smartass
I changed the check valve out 3 times. That wasn’t the problemcheck valve
No need for an extension cord if you have a small 12VDC to 110 VAC inverter connected to theTM battery!110vt.
cheap (relatively) to install an in-tank sewage pump if/when you run an extension cord to power it.
I did that with my Powermatic.
water tight electrical fittings and conduit thru the tank to plumb
1/2"?It's counter-intuitive, but a SMALL diameter discharge hose works more reliably on that type of pump to overcome vacuum.
I had 3/4"Is 1/2” smaller?
Who runs check valves since theI changed the check valve out 3 times. That wasn’t the problem
Buckboard stage and valve co ltd!!!!Who were you employed by back then Bob?
