- Oct 25, 2016
- Name
- Swani
One of my customers had a leaky roof and the cabinet that was on the carpet left this spot. I'm thinking of encaping? Any other ideas? Here's the picture she sent me.
What is a blended solvent?
After second look I would try a rust remover on a small spot too.
I'll give it a try Scott. I carry All Solv Extreme and Stain Magic.Since we don't know about the wood stain or finish, we can't say this solvent or that solvent will work. A blended solvent has a blend of several solvents. One is more likely to work. An example would be Bridgepoint's All Solv Xtreme which is a blend of 8 different solvents.
OR, apply stain magic, rub W/Fels, AND, blast with STRONG blacklist light.... 5-10 min should do it....I'd flush it then stain magic and cover with saran wrap and a weighted object to keep the air out. Stain should be gone next day.
If it doesn’t work, Apply sally vol. 40, BLACK LIGHT AGAIN 5-10 min....OR, apply stain magic, rub W/Fels, AND, blast with STRONG blacklist light.... 5-10 min should do it....
You better stay off the tracks when I'm coming through! Lol!Nick, I hope you drive a train better than your carpet stain problem solving thoughts......
most furniture stains are difficult at best,
The majority of them can only be removed completely with a knife
that stain in the pic looks like a great place to put a cabinet ...over the wood stain that will more than likely remain
Which solvent is that? I would like to take a look at it.I ordered the solvent that cobb alway advertising. I hope it works. TSW is running out..
Great advice, thanks! I haven't made any promises just told her I would give it a try.furniture/wood stain reality 101
Consider them as permanent , and explain the unfortunate reality to the custy
Don't even suggest you can "improve" them ..even a little , cause you most likely can't
any that will respond to latest/greatest wonder spot juices, will more than likely respond to the Gels, fels, juices most carry
seriously, Nick
figure from the get-go that furniture stains are permanent ...cause 94.279% are
Proceed with caution with wonder juices in an attempt to improve them, but don't make any promises to the custy
And often, when trying to be a hero, the aggressive efforts cause discoloration of their own.furniture/wood stain reality 101
seriously, Nick
Definitely hard to say "when" and admit defeat!And often, when trying to be a hero, the aggressive efforts cause discoloration of their own.
