Pro1200 se
California
Ok the check engine light comes on and I googled and I'm finding it has to do with the thermostat?
It does go back off and the water temp guage never goes over 210
Also why the 570 and pro1200 must have the same idiot gluing the lid gasket on both failed in less then 6 months.
With that said I replaced my 570's two years ago still doing great.
California
Also I messaged AM who has a pro 1200 asked about belts and when they should be changed, I'm clocking 450 hours on my machine in 6 months of owning it.
He said I still have my original with 300 hours after 2 years?
What?
Do you people even clean carpet?
Chris A
OH
Chris
Lol, mine on the 2015 are original with 1400 hours. The 2016 had them replaced because one popped from a flat spot. I'm not sure what the manual says.
I've started smelling burned rubber on mine when I shut it down. Must be time to change them.
View attachment 74519 View attachment 74520
You googled what?
What is the code?
California
You googled what?
What is the code?
You know me I read something didn't pull codes or anything,
But it happens when I do upholstery.
Not enough flow possibly, also tile and grout, or if I run out of fresh water.
I'm guessing it's related to the thermostat.
But ya I should have it looked at it's under warranty.
Just asking here to see if anybody else with a DD Sees it.
@Mark Saiger
Mark Saiger
Mr Happy!
Grand Rapids, MN
Mark Saiger
@Mark Saiger
No codes for us but I wonder if the mass air flow filter has something maybe in it.
Or 02 sensor...
But would get that code checked
California
Just going to say this, the light never goes on while just driving, only when the machine is in use.
And then it can stay on for up to a day and clears.
Redding
One of the local guys here in Redding has a Pro1200. I see him cleaning with his hood up. I'm hearing that this is the thing to do with these mounts. Beautiful machine.
I'll put it up on bigger jobs. Less heat to the wand but the van runs a lot cooler.
