Vlm caused white streaks
Yukon, Oklahoma
You get the pad wet, and it helps keep it wet as you go. Certainly with just a little experience it’s not a big issue. You certainly don’t have to stop and spray which is essentially the same thing.
I think the best answer is pony up the cash for a Trinity Phoenix or a Sprayborg. It sprays ahead of the machine evenly and the pad works it in.
Yukon, Oklahoma
Of course that’s true or a Vibe. I said, if he was gonna use a 175, a tank still beats spraying with any type of of sprayer, and way cheaper too.
they live
Michigan
Steve
The only issue with running a shampoo tank with a bonnet is that the solution won't flow/disperse through the bonnet very well.
It slings off the top of the pad driver in 360 degrees so its always spraying where you are going.
You do have to back it up to pick up the spray behind the machine though. It becomes part of the routine. 2 steps forward while triggered one step back. A lot of overlapping.
Reactions: Kenny Hayes
