water in my cat
Noble Carpet Cleaners
sucks but sometimes mechanisms fail earlier then perhaps many other like it. Tiny amonts of water could be sneaking past the piston seals. Just monitor it and see how she goes..
1200 hours..
If your chemical pump diaphragm is ruptured it can Mike.
Do you turn your pressure up around 1000 psi and above for hard surface cleaning from time to time?
GeneMiller
Boca Raton
gene miller
That doesn't look right. Something else is going on. Your water softner is running salt through. Check the water in the tank that goes to the pump. What's really in it.
Gene
ronbeatty
Altoona,PA
Ron Beatty
I just had a 5cp pump rebuilt after 700 hrs, Cat said the check valves and seals showed excessive wear:hopeless:. The older style Cat pumps that Butler used would go 3500 hrs plus. My next pump will be a General, half the price and from what I hear a much better pump.:rockon:
Benton KY USA
The General is a better pump, with one weak link: It MUST be pressure-fed to avoid cavitation. More so with hot water input.
ronbeatty
Altoona,PA
Ron Beatty
I was experiencing erratic chemical flow and a drop in operating pressure. I got it back after the rebuild it worked for a couple of weeks and then started acting up again. I ordered a new one will be here on Thursday.
dgardner
Phoenix, AZ
Dan Gardner
Not exactly. My (probably incomplete) understanding is that cavitation occurs when there is rapid fluctuation in local pressure below the saturated vapor pressure of the water. Temperature is involved because the pressure where cavitation occurs (at a given pressure) goes up as temperature rises. So, increasing the inlet pressure and/or reducing the liquid temperature can cure cavitation.
When the piston draws in liquid through the inlet plumbing and past the inlet valve there is always some pressure drop. Poor plumbing (tubing too small, restrictive fittings) make the situation worse. The water level above the pump inlet makes a difference as well. The higher the level - the more pressure (head, as the pump guys say) is exerted at the inlet, helping the situation. Make the pump draw water uphill (water box below pump) creates low pressure (vacuum) making the situation worse.
You can create cavitation at any temperature (with enough inlet restriction and/or low enough inlet pressure) but high temperature makes matters worse (much worse, as you approch boiling).
A planet far far away
I thought pressure would control cavitation from occurring? Or Does it just keep water from boiling?
Off the subject but still about cavitation we use ultrasonic machines to clean fire damage items. It uses transducers to create a frequency that creates cavitation. Its that the same kind of activity that goes on in a pump? Can it damage the pump?
If you leave and item in an ultrasonic machine to too long it will strip the paint or plating off them.
dgardner
Phoenix, AZ
Dan Gardner
The higher the level the more pressure (head, as the pump guys say) is exerted at the inlet, helping the situation. Make the pump draw water uphill (water box below pump) creates low pressure (vacuum) making the situation worse.
Yes, as I mentioned - pressure does help. Enough pressure (for the temp you're running) will stop the cavitation.
Take a pump that you're feeding 180° water that is cavitating. You could increase the pressure to stop it - or reduce the temperature. It's a little like TACT - What you dont do for one piece you can make up with another piece.
dgardner
Phoenix, AZ
Dan Gardner
The transducers actually vibrate at a certain frequency to produce a pressure wave - which is high and low pressure variations - sound familiar? it's the pressure transitions that create the cavitation (voids) and as the voids violently collapse they generate a shock wave that does the cleaning (in the ultrasonic machine) or the damage (in the pump).
That's where I always thought it was heat that caused it but from your explanation I now see it can more than heat.
In the ultrasonic its doesn't have to be hot water used but it works better in hot.
Reactions: dgardner
Fort Worth , Texas
Which is what is wierd in this situation.
As mikes machine as well as rims machine are newer aerotechs that have the pump Mounted to the floor in the box well below the fluid or water level in the fresh tank.
You will notice the cat pump right in front of blower on floor of truck.
Older trucks like mine have the pump mounted above the blower always above the water line by at least a foot or so and the pump has to pull one foot up and at least two feet across to get the water.
I had cavitation but only because of that General pump fine inlet strainer connected to pump would suck a bit of air, once removed never have had cavitation again. Our tanks after a couple of hours will hover at 150-160 degrees preheated by motor while driving around.
I will pull one of my cat pumps apart to see if I had that type of wear going on.
That didn't look so much like wear as it did something aggressively attacking it. ???
Dan would the cavitation eat away at the pump the same way an ultrasonic machine will eat at an item left in the tub too long?
Fort Worth , Texas
That is what I mean as the brass plug mike has posted a pic of does not move, it is stationary. The plunger moves in and out of the middle of it creating pressure in the head. So what ever is "wearing or eating" it has to be in the water.
dgardner
Phoenix, AZ
Dan Gardner
I agree. severe cavitation can/will erode the pump materials but not (in my experience) discolor them like that. Certainly looks like either chemical attack or electrolysis to me.
